Logitech G403 Prodigy Wireless
Go to solution Solved by DrDerp,
This mouse is Full RGB, as in you can customize it however you want. If you want a flat white you can set it to that, if you want it off, then you can turn it off.
Who needs fancy graphics and high resolutions when you can get a 60 FPS frame rate on iGPUs?
