Posted September 21, 2018 I plan on buying and spraying the Noctua NH-D15 SE-AM4, only the frame and the blades, not the heatsink. 1.- Would any spray paint withstand the temperatures of being near the heatsink? 2.- If not, which spray paint would? Thank you Link to comment https://linustechtips.com/topic/974482-spray-paint-cpu-cooler/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 21, 2018 Author 2 minutes ago, wONKEyeYEs said: I don't know if you would need heat resistant paint for those parts, but it is a thing. I just saw other posts mentioning it so I thought I would ask, do you thing any spray would do? (non-heat resistant) Link to comment https://linustechtips.com/topic/974482-spray-paint-cpu-cooler/#findComment-11777334 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 22, 2018 temperature should not be a concern. ive done a nh-d14 HSF and fans: issues that may be concerning is the amount of paint used on the fan blades. do not allow the fan to sit heavily to puddle or making it too thick in places. multiple light coats. Link to comment https://linustechtips.com/topic/974482-spray-paint-cpu-cooler/#findComment-11778503 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
