So, I am well aware about the Vram guide on this forum. My question though is arisen from recently planning on getting 2 RTX 2080 Ti's for SLI.  And I already have 1 32 inch 4k monitor that I love , But I have the opportunity to pick up 2 more of the same monitor for a REALLY good deal rn.  The thing is , Idek if 11gb is enough to do such a thing...
I'm fairly confident in the cards holding up most current games at at least 30 fps maxed out on 3 monitors if i overclock them well,
But again, can 11gb actually hold with that many pixels?
I can't really find alot of good information on this as this isnt a common setup to run.. so if anyone has any input, that would be great.
Thanks.
https://linustechtips.com/topic/963520-vram-usage-for-triple-4k/
I'm not sure if it'll run amazing but I'm sure if you tune the settings you could get playable fps, however playing a game on 3 32 inch monitors will require a lot of head movement and doesn't seem like it'll be optimal but if that's what you want, then go for it lmao. The Rtx series will prob have a 25%-35% jump in performance so just calculate that times current hardware to get a guess on how much performance you'll get.
