SSD an OS help
Solved by seagate_surfer,
18 hours ago, Mario Ezquerro said:Yeah that might be it but i have no idea what could have went wrong during the installation
Maybe not only during installation, moving the drive, unplugging/plugging it back, applications installed corrupting system files/boot files and let's not forget about damaged sectors. Everything counts but the thing is that the drive cannot boot, so try it on another computer or different slots/ports if you don't have access to a secondary machine, format your drive again, boot only with this drive connected, what you need is to isolate the problem of the drive and if problem persists I would recommend you to do RMA on that unit.
