I am looking to make my first PC since I currently play on a Mac and well #PCMasterRace. I was wondering about what range should I go for with my graphics card. I was thinking something like a GTX 1060 or 1070 once the new series comes out which will cause the price to drop. Are these good options? I'm obviously not looking for the highest end performance in games, just something that won't want to make me throw up. Also if you could give me a price that I should pay for both, or if you had another GPU in mind please give a price. Thanks for any help you can provide.
https://linustechtips.com/topic/958304-first-pc-graphics-card/
We need to know what resolution your monitor is.  This effectively determines how much video card HP you need.
Minimum I'd go with a 1060 6GB, any dual or triple fan version is fine, for a standard 1080p monitor.  1070 for 1440p monitor or a high refresh 1080p.
Under $300 for a 1060 6GB, under $400 for a 1070.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/958304-first-pc-graphics-card/#findComment-11629053
1060 and 1070 are both excellent cards. I would rather go for a 1160 though as it will most likely outperform the 1070 even.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/958304-first-pc-graphics-card/#findComment-11629054
1060 6GB runs 1440p fine if it isn't AAA games and on ultra settings according to a lot of benchmarks I've looked at. The 1050 ti is fine for 1080p for medium-high quality and the 1060 3GB is good for high quality 1080p gaming (definitely not ultra). This of course only applies to 60fps and not to higher, you likely need a 1070 then. I would get a 1160 if it's about the same price.
https://linustechtips.com/topic/958304-first-pc-graphics-card/#findComment-11629070
The 1060 6GB may run non-AAA games at 1440p at non-ultra, I will accede that.  But what happens in 12 months when games push the envelope further?  Keep reducing settings?
Buy a card for the future, not the present. For AAA titles, because in 6 months a AAA title may come out you really want to play.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/958304-first-pc-graphics-card/#findComment-11629077
I've found a couple of options that I think would work. I found an RX-480, which I figure is about as good as a 1060 for $250. But I might be able to get it down a little bit. I also found a GTX 1070 Founders edition for $300. Are either of these good deals and are they worth getting?
https://linustechtips.com/topic/958304-first-pc-graphics-card/#findComment-11630962
GTX1070 for $300 is what you want.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/958304-first-pc-graphics-card/#findComment-11639707
