So I have an MSI GTX 970 and it doesn't work with my P8Z77-V LE mobo, but when I try this gpu in an old phenom system from like 2010 it works great, that pc has an 550w psu and mine has an 850w, Do I need to buy a new mobo to fix this issue? Cuz I get no display and blackscreen, cant get post when the gpu is connected. Ive seen other people having problem with the 970 and the z77 motherboards, I have the latest bios installed.
I get no picture on the other slot either!
SYSTEM:
i7 2600k @4.5
24GB RAM
GTX 660ti oc edition (using it rn since 970 doesnt wna work in my pc)
P8Z77-V LE
xfx pro 850w
https://linustechtips.com/topic/954742-problem-with-gtx-970/
Had no issues with my 970ssc on my z77.
Boot with igpu and ensure the card is being recognized in the bios and device manager.
https://linustechtips.com/topic/954742-problem-with-gtx-970/#findComment-11598082
yes when I do that I can see the gtx 970 pop up in device manager with an orange triangle, code 43, tried installing drivrs to it and it doesnt help either.. Do i put pcie as main I often get black screen and sometimes I got picture but very low res and the screen freezes and I need to reboot.
https://linustechtips.com/topic/954742-problem-with-gtx-970/#findComment-11598109
I tend to reseat the card and move it to another slot of that doesn’t work. I’ve had those kind of issues but know the card worked so I know it couldn’t be the issue.
https://linustechtips.com/topic/954742-problem-with-gtx-970/#findComment-11598976
