I'm looking to build my first pc for gaming of all kind from Far cry to minecraft. I'm in the USA i have a budget of about $5,000 i plan on having at most 3 monitors but will only start out with one to have more for the parts for the pc. The monitors i plan on having will have a resolution of 2560 x 1440. I plan on using the Thermaltake Tower 900 Black Tempered Glass Fully Modular E-ATX Vertical Super Tower for my case if you could suggest on parts i should use would be very helpful
https://linustechtips.com/topic/952001-planning-my-first-build/
The case is going to look a bit bare since it won't have a custom cooling loop.
All RGB components are Aura Sync compatible and can be synchronized through the motherboard. This includes the keyboard and mouse. The two fans are for the top exhaust mounts. The 4TB hdd is there just for media and archives. Pretty much everything else can be stored on the 2TB NVMe M.2 drive.
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($347.69 @ SuperBiiz)
CPU Cooler: Cooler Master - MasterLiquid ML240R RGB 66.7 CFM Liquid CPU Cooler  ($173.88 @ Newegg Marketplace)
Motherboard: Asus - ROG MAXIMUS X CODE ATX LGA1151 Motherboard  ($279.99 @ B&H)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3200 Memory  ($250.88 @ OutletPC)
Storage: Samsung - 970 Evo 2.0TB M.2-2280 Solid State Drive  ($793.99 @ Amazon)
Storage: Seagate - IronWolf 4TB 3.5" 5900RPM Internal Hard Drive  ($118.49 @ OutletPC)
Video Card: Asus - GeForce GTX 1080 Ti 11GB STRIX GAMING OC Video Card  ($829.99 @ Amazon)
Case: Thermaltake - The Tower 900 ATX Full Tower Case  ($218.99 @ SuperBiiz)
Operating System: Microsoft - Windows 10 Home Full - USB 32/64-bit  ($103.95 @ Trusted Tech Team)
Case Fan: Cooler Master - MasterFan Pro 120 Air Flow RGB 48.8 CFM  120mm Fan  ($18.16 @ Amazon)
Monitor: Asus - PG27AQ 27.0" 3840x2160 60Hz Monitor  ($806.61 @ Amazon)
Keyboard: Asus - ROG Claymore Core Wired Gaming Keyboard  ($277.88 @ PCM)
Mouse: Asus - ROG Gladius II Wired Optical Mouse  ($79.99 @ Amazon)
Headphones: SteelSeries - Arctis 7  Headset  ($138.90 @ Amazon)
Total: $4457.55
Generated by PCPartPicker 2018-07-25 12:00 EDT-0400
https://linustechtips.com/topic/952001-planning-my-first-build/#findComment-11574127
Tank you both for the suggestions i plan on a later day after the main build to but in a custom cooling loop but i just wanted to get it built first to keep down on the cost then save up more for the cooling system but over all they both look like amazing builds once i get all the parts and get it together ill make sure to post about it when its done
https://linustechtips.com/topic/952001-planning-my-first-build/#findComment-11574912
