Hey guys! my whole game was fine until two or three months ago. Since then I stopped playing, and today decided to play some good old Battlefield1. I was hitting 60-80 FPS on high preset in conquest and operations 2 or 3 months ago. Now, I'm hitting about 25-40 FPS in said gamemodes, on the lowest possibble settings. anyone having the same issue, or is there someone with a possibble fix? thank you!!!! <3
Setup: I5-4460, GTX 1060 6GB, 16GB 1866MHZ RAM, 1TB harddrive with plenty of space left, win10 64bit.
https://linustechtips.com/topic/950873-problems-with-battlefield-1/
-Moved to Troubleshooting-
Check your drivers, make sure those are up to date.
4 hours ago, shit boi said:
drivers are indeed up-to-date :/
Uninstall using DDU and try an older driver.
