Wireless Sound Sending
Go to solution Solved by SuperOwnJK,
Figured it out!
Installed Shairport4w on desktop to use an an airplay receiver (http://sourceforge.net/projects/shairport4w/)
Macbook detects it has an audio output device.
Have an odd issue, wondered if anyone knows of any software that could help.
I want to play music from my Macbook Air to some speakers in another room wirelessly. The speakers have a 3.5mm jack on them. I have a Windows Desktop that could be used to bridge the music.
My first idea was to play the music on the desktop using Google Music All Access through Chrome, and use remote desktop on my Macbook to control it, but the Desktop is a bit shit and sometimes the audio breaks up.
So what I'm after is a piece of software that sends the audio from my Macbook, to the Desktop over the LAN....if any exists. It must be cross platform too of course.
Intel Core i5 2500k @ 4.2GHz | Corsair Vengeance 16GB 1600MHz | MSI GTX660 Twin Frozr II OC | Samsung Evo 850 250GB | Seagate Barracuda 3TB | Corsair 600T White | Corsair H100 | Corsair HX850 | Corsair SP120 QE | Asus MX279H | LG Flatron E2251 | Logitech G502 | Das Keyboard Ultimate 4 Browns | Fiio E10 | Beyerdynamic Custom One Pro | Corsair SP2500 | HTC One M8 | MacBook Air (Mid 2013) i5 8GB 128GB
https://linustechtips.com/topic/94953-wireless-sound-sending/
PLEX server should do the trick. It's free.
https://plex.tv/
But would it be able to take my audio from my Macbook, and play it through the Desktop?
Or would the Plex Application play the music just on the desktop?
https://linustechtips.com/topic/94953-wireless-sound-sending/#findComment-1272283
http://www.amazon.co.uk/gp/product/B0057BAB60/ref=wms_ohs_product?ie=UTF8&psc=1 I use one of these just plug it into my speakers, all of my gadgets and pcs have bluetooth so I can change input easily. dont know about software though
I was debating that but I don't really want to spend any money as its for 1 night.
https://linustechtips.com/topic/94953-wireless-sound-sending/#findComment-1272329
Figured it out!
https://linustechtips.com/topic/94953-wireless-sound-sending/#findComment-1272395
