So basically, I have a 1TB WD MyPassport USB HDD that the cable for it only works through a USB hub but not when connected directly to the computer, Any Ideas as to why?
 Main Desktop
CPU: Intel Core i7-14700KF
CPU Cooler: Arctic Liquid Freezer III A-RGB
MB: ASUS ROG STRIX Z790-F Gaming Wifi II
RAM: 32GB(2x16GB) Team T-FORCE Delta RGB 6000MHz DDR5
GPU: ASUS ROG STRIX RTX 4070ti 12GB
STORAGE: 2.048TB Kingston KC3000, 2TB Crucial T500, 250GB Samsung 850 Evo, 1TB Samsung 970 Evo Plus, 240GB WD Green M.2 SATA SSD
CASE: Montech King 95 Pro
PSU: Be Quiet! Straight Power 12 1000W
OS: Windows 10 Home
Monitor: Samsung Oddessy G6 27" 1440p, Viewsonic VX2455 144Hz
Mouse: Logitech G502 Lightspeed Wireless Mouse
Keyboard: ASUS Flare II Animate
Headphones: HyperX Cloud Alpha S Black
Microphone: HyperX Quadcast S
https://au.pcpartpicker.com/user/johnno12/saved/4HDc4D
1
Laptop:
Dell Inspiron 15-5000
CPU: i5-8250U Quadcore with hypertheading
GPU: AMD Radeon 540 4GB Hybrid Graphics
Storage: Micron 1100 SATA 256GB SSD
OS: Windows 10 Home
1
https://linustechtips.com/topic/925102-usb-cable-not-working-properly/
try a diff cable?
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
Is the USB hub powered by an external source?
Maybe your USB ports are not able to supply enough power for the disk to run.
The front USB ports are not able to do this on my Medion desktop, as well as the USB port on my Thinkpad 10.
If you use a desktop you could try to use the rear ports on the motherboard. In case of a laptop I would try all of the ports.
