Driving me insane, please help.
Hey all,
So I've had my PC for a couple months now, and twice this bizarre and infuriating thing has happened (btw I don't know if this is the right place to post as I'm not even sure what kind of issue this is).
The first time it happened, I completely reset windows and it seemed to be fixed. But now it's happened again and is completely crippling for everything I use my PC for. This was completely out of the blue (yesterday it was going fine, today its a mess). So here's a list of what happens:
 - When I turn the PC on, gputweak automatically opens as does ledcontrolservice, which appears to control my GPU lighting.
 - I cannot restart, sleep, hibernate, or shut down my pc with the buttons in windows. This can only be done by holding down my chassis power button. If I try to shut it down through windows, it displays the shutting down screen with the spinning logo, but my PC stays on with a green led illuminated.
 - Task manager is frozen. The information on it updates extremely slowly, like once every 30 seconds. I can't end tasks, change startup applications etc.
 - Chrome will not open and will instead be a white screen, soon followed by an invisible window title "Page unresponsive".
 - I can't open applications like steam, origin, etc. They open and appear in task manager (static, of course) but do not appear on the screen or in the taskbar.
 - One particular program, the Star Citizen launcher, appears as a transparent window when opened.
 - Discord opens fine and works.
 - MS Edge (which I used to see if web browsing worked) cannot access webpages and freezes when I try to open it.
Honestly, I have no clue what could be causing this, and it means my PC is simply unusable. I don't know if it's a hardware thing or a software thing.
My specs are:
 - R5 1600
 - X370-F ROG Strix Motherboard
 - 16GB 3000mHz ddr4 G.Skill trident z
 - Asus ROG STRIX 1060 6GB
 - MX500 500GB ssd (C drive)
 - WD Blue 1TB HDD (E drive)
 - Corsair RM 650i PSU
Help is appreciated!
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
https://linustechtips.com/topic/921140-driving-me-insane-please-help/
The first thing I would do is boot windows in safe mode to eliminate conflicts from services. This could be why resetting Windows helped. It temporarily disabled the service causing the issues.
If the above helps, restart and use run -> services.msc to disable all services (remember to click "hide microsoft services"). Then systematically enable services one at a time until the problwm begins again. Then you will have found the issue.
Also make sure you update the BIOS and all drivers. I've had really weird issues from BIOS problems with system hang or unresponsiveness.
If this doesn't work, it might be a bad memory module. Run MemTest to rule that out.
I'll try that, thanks.
BIOS and drivers are up to date, I ran MemTest a little while ago to test as well.
My PC:
So I couldn't get into safe mode (help shift and hit restart) because my computer would just blackscreen while running. However I noticed when it was trying to restart that uxdservice was under the list of programs that it says "stopping 2 services and shutting down". I know this is nvidia related but I don't know how I could stop it.
My PC:
So I used msconfig to go into startup diagnostic mode, then went back to normal mode and that's seemed to fix it... I have no clue why but thanks for your help anyway!
My PC:
