Evening All,
Okay really really quick question. I have two SSD's in my system both around 500gb. A Samsung 850 Evo and some random off brand SK Hynix maybe you've heard of it but its new to me. I currently have them as separate drives, use the Samsung for OS, Games & Documents and the other one purely as a download drive. Files get downloaded onto the Hynix and then moved over to the media server. Should I convert them to Raid 0? that way I get the combined storage and a possible performance increase. I have nothing locally that can not be lost, just games and OS. I am aware of the risks with raid 0 but not the extent...
So my question is Does Raid 0 wear out disks FASTER than using them as a single drive?
Thanks,
https://linustechtips.com/topic/920908-raid-0-x2-ssds/
SK Hynix... off brand?
It's not worth it. You won't see much difference in real world performance, but you get all the issues that come with RAID 0. Only time RAID 0 is worth it is for scratch disks IMO.
EDIT: Also, to put them in a RAID 0 array, you'll need to format both of them in the process.
https://linustechtips.com/topic/920908-raid-0-x2-ssds/#findComment-11283942
