Hi i need to ask somebody to help with upgrading my gpu. I used to have an amd r7 250 1gb as my gpu of my pc which i recently upgraded the motherboard and its cpu. But the gpu had stopped working and ive already had a cheap old gpu which is a gtx550 ti disguised as a gtx750. Now im plannimg to buy a gtx 1060 3gb to replace but idk if my computer can handle it without bottleneck and such.
https://linustechtips.com/topic/918979-need-upgrade-advice/
What CPU do you have?
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/918979-need-upgrade-advice/#findComment-11265769
If I were you I would opt for the 6gb variant as they're actually two different cards, and there are other differences other than the memory buffer. It would be a bit more future proof.
         -Jingyuan Chen-
                          Intel i7 8700 | EVGA GTX 1080ti SC2
16 GB 3000mhz Trident Z Ram | Asus STRIX Z370-E
    Benq ZOWIE XL2735 | AudioEngine A2+
              Dubai, United Arabs Emirates
https://linustechtips.com/topic/918979-need-upgrade-advice/#findComment-11267885
