No POST after overclocking fail
Go to solution Solved by xriqn,
3 minutes ago, Nekotronics said:
Shit. Its 2 days old.
Try RMA it ;)
If that's unsuccessful, just get a 2200G for now, they're pretty cheap.
https://pcpartpicker.com/product/RkJtt6/amd-ryzen-3-2200g-35ghz-quad-core-processor-yd2200c5fbbox
Having some issues getting my computer to post after an overclcocking fail. I've tried clearimg CMOS (by powering off completely and removing battery, then junping clear CMOS). Having no luck, any suggestions?
Specs
Ryzen 5 1600x
Msi x370 gaming plus
Gtx 960 4gb
1x8gb ddr4 2666mhz
700w psu
Side note: i tried to overclock to 4.0ghz and 1 step up on cpu voltage from stock. Not an insane overclock.
https://linustechtips.com/topic/918057-no-post-after-overclocking-fail/
Clear CMOS by removing the battery. You may not have hit the right jumper
Is it not booting up at all? Or are the fans spinning and whatnot? Any error lights or codes?
Worst case scenario you fried your CPU, but I doubt that happened.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
Fans spin but then ramp down after about 10 seconds. Motherboard doeant have a code reporter (a digital one anyway).
pull the kettle lead out your pc
if you got onboard graphics and are comfertable taking it out gpu do that
disconnect ALL USB and SATA devices from the motherboard (easiest is just pull satas and leave them near the board)
make sure all power pins on the motherboard is satisfied 8pins etc
While I am here have you checked the linustechtips post list lol
with the kettle lead out, hold the power button for two mins, then replug kettle?
EDIT: read first
EDIT: read first
if you knew hardward, you would know that the Ryzen 5 1600x does NOT have on board graphics...
Community Standards
"Beast Mode"
Dedicated Streaming Rig
What voltage did you set it at? If you set it too high you probably fried your CPU.
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
EDIT: read first
Read the thread, still having problems. Tried your method aswell
Just now, Nekotronics said:
I set it 1 bump up from stock so i dont think i fried it but its possible
Tried resetting your CMOS? If you have a case like mine there's a reset button so u dont even need to open the PC up.
1 minute ago, Nekotronics said:
I have tried it but no dice
This is really weird, you only put the multiplier (I assume) one up from stock but it may just have fried your CPU. By stock do you mean normal clock or the stock boost? Got my fx 6300 at 4.4ghz and haven't fried that.
Put multiplyer to 4.0ghz and voltage to somewhere around 1.38 or 1.39
Update: found motherboard light signals and it seems to indicate that "CPU is not detected or fail."
RIP CPU. Sorry for your loss.
Try RMA it ;)
Ive had issues with pcs before, where literally leavin it overnight has fixed the weirdest stuff, so dont assume the worst right away.
Have a rest
Maybe reseat it
redo the ram, many ram mishapps cause cpu not showing errors
Have a rest
Maybe reseat it
RAM errors shouldn't screw things up with the CPU so badly that it's not detected. lol.
Change teams if you like to overclock.  5GHz is a lot more fun than 4GHz...just sayin'
Try reseating the CPU, reseating the Ram, reseat the CPU power plug, try the CPU in a buddies machine, remove the Mobo and try to fire it on the bench, blind flash the bios, etc.  Lots of things to try before putting her out to pasture.
i9-9900k @ 5.1GHz || EVGA 3080 ti FTW3 EK Cooled || EVGA z390 Dark || G.Skill TridentZ 32gb 4000MHz C16
 970 Pro 1tb || 860 Evo 2tb || BeQuiet Dark Base Pro 900 || EVGA P2 1200w || AOC Agon AG352UCG
Cooled by: Heatkiller || Hardware Labs || Bitspower || Noctua || EKWB
Like TahoeDust said, try reseating stuff.
SPECS:
