I'm looking for a cheap gaming pc build. This is a cheap pc and GPU I found. I just want to double check if this pc and GPU even works together. Thank you!
PC: https://www.amazon.com/HP-Quad-Core-Windows-10-Refurbished/dp/B01CV9G1BO/ref=sr_1_3?ie=UTF8&qid=1524080950&sr=8-3&keywords=hp+elite+8300
GPU: https://www.amazon.com/ZOTAC-GeForce-Express-Graphics-ZT-71115-20L/dp/B00R5UW038/ref=sr_1_1?s=electronics&ie=UTF8&qid=1524081285&sr=1-1&keywords=zotac+geforce+gt+730+4gb
will I need a new power supply?
https://linustechtips.com/topic/918000-graphics-card-and-pc-help/
That card will not fit in the case, it's too high profile. You'd want something more low-profile such as this: https://www.newegg.com/Product/Product.aspx?Item=9SIAE8D6Z63114&cm_re=low_profile_video_card_pci_express_x16-_-9SIAE8D6Z63114-_-Product
What's your max budget? You'd probably be better off just building a PC.
-Moved to New Builds and Planning-
The tower is fine, although those HP SFF units tend to be funny when it comes to power over PCIe. make sure  your graphics card uses less than the 75W that PCIe is specced for just incase.
I'd reccomend a GT 1030 over the 730 all day.
I'd reccomend a GTX 1050 low priofile too, but i know those HP SFF PCs can be weird about power.
If you get the GT 1030 or GT 730, you wont need to upgrade the power supply.
Also, you can get mid/mini tower PC's that will fit much larger graphics cards for considerably less than $200
Share any interests with me? Feel free to message me just to chit chat about whatever.
(Music) Depeche Mode, The Cure, Pink Floyd, Nick Cave and the Bad Seeds, Cocteau Twins, MGMT, Boy Harsher, The Smiths, Drab Majesty, Chelsea Wolfe, Carly Rae Jepsen, The Smashing Pumpkins, Virgin Prunes, Sky Ferreira, London After Midnight, Jonathan Coulton, Alvvays, Clan of Xymox, Bauhaus, Siouxsie and the Banshees, Anna Von Hausswolff, Joy Division, Sisters of Mercy, She Wants Revenge, The Frozen Autumn, My Bloody Valentine, Type O Negative, The Birthday Party, Leonard Cohen, Switchblade Symphony, Metallica, Creedance Clearwater Revival, Eagles, Elton John, Billy Joel.
(Games) PUBG, Metro Series, Command and Conquer games, Warhammer 40,000 games, Company of Heroes (2), RDR2, CoD4
(Other) Going to the goth club, Firearms, Building PCs (Especially budget PC builds), Playing instruments (Guitar, Piano APP for PC, Otamatone, Trombone) Camping, Board Games
This graphics card includes a low profile bracket.
This will work fine
This will work fine
Did it? I missed that.
yeah, pretty sure
"Package contents: ZOTAC GeForce GT 730. 1 x Low-profile bracket [VGA]. 1 x Low-profile bracket [DVI + HDMI]. User manual. Driver disc"
4 minutes ago, BarackOBatman said:
yeah, pretty sure
so it will work with the low-profile bracket? and it will fit the case?
It should work and will fit yes, but if you don't mind the PC being a refurbished, I strongly suggest the following combo as an alternative
The CPU is a generation older but the difference in performance will be negligible compared to $100 price difference.
The graphics card is like 3 times better. not even joking.
You'll probably also want to pick up some more DDR3 since this comes with just 2 GB You can get 2x4GB (8gb) for $50 or so if you hunt a little.
Just dont get a single 8 gb stick. The chipset probably wont like it. Or just toss a 4GB stick alongside the existing 2GB for $30 or so. (6GB total)
https://www.newegg.com/Product/Product.aspx?Item=N82E16883288121
https://www.newegg.com/Product/Product.aspx?Item=N82E16814487373
I think I'm going to use this as an alt to my current build I wanna do. Thank you for your help! Hopefully this works.
