Hi,
Since I built my new pc (parts listed at the end of the post) I have been experiencing a critical problem that freezes my pc. The event log refers it by "kernel power 41 (63)". It can't be a virus since I've formatted my pc several times and spybot cannot recognize any problems. I have tried updating some drivers, updating my bios, disabling my OC and running a test on my RAM. I have only recognized one pattern: This problem occurs while playing games for excess amounts of time (so far only CSGO, PUBG or Fortnite)
Usually the information displayed about this event is such:
System
- Provider
      [ Name] Microsoft-Windows-Kernel-Power
      [ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
  EventID 41
  Version 6
  Level 1
  Task 63
  Opcode 0
  Keywords 0x8000400000000002
- TimeCreated
      [ SystemTime] 2018-03-11T20:05:25.227863700Z
  EventRecordID 6537
  Correlation
- Execution
      [ ProcessID] 4
      [ ThreadID] 8
  Channel System
  Computer DESKTOP-ARBPR23
- Security
      [ UserID] S-1-5-18
- EventData
    BugcheckCode 0
    BugcheckParameter1 0x0
    BugcheckParameter2 0x0
    BugcheckParameter3 0x0
    BugcheckParameter4 0x0
    SleepInProgress 0
    PowerButtonTimestamp 0
    BootAppStatus 0
    Checkpoint 0
    ConnectedStandbyInProgress false
    SystemSleepTransitionsToOn 0
    CsEntryScenarioInstanceId 0
    BugcheckInfoFromEFI true
    CheckpointStatus 0
However yesterday after updating my bios I got a "new" kernel power 41 while idle. Information about this event:
- System
- Provider
  EventID 41
  Version 6
  Level 1
  Task 63
  Opcode 0
- TimeCreated
      [ SystemTime] 2018-03-11T20:45:36.766671400Z
  EventRecordID 6604
  Correlation
- Execution
      [ ProcessID] 4
      [ ThreadID] 8
  Channel System
- Security
      [ UserID] S-1-5-18
- EventData
    BugcheckCode 0
    SleepInProgress 6
    BootAppStatus 3221225684
    Checkpoint 0
    SystemSleepTransitionsToOn 1
    CheckpointStatus 0
 PC parts:
GPU: MSI GTX 1070 8gb Armor
CPU: Intel i5 8400
RAM: Corsair Vengeance 8gb DDR4 2400 mhz
Mobo: Asus Prime Z370-P
PSU: Corsair CX650
HDD: Barracuda 1TB
SSD: Kingston UV400 120gb
https://linustechtips.com/topic/905014-strange-kernel-power-41-63/
Kernal power error 41 occurs when the computer is shut down, or it restarts unexpectedly. When a computer that is running Windows starts, a check is performed to determine whether the computer was shut down cleanly. If the computer was not shut down cleanly, a Kernel Power Event 41 message is generated.
Does your pc reboot when it freezes or do you hard reboot it like holding down the power button to turn it off when it freezes?
