Hi there.
I am going on a vacation this summer, and I wanna vlog it.
But I'm not going to be able to buy a camera before we go. So I can just use my phone!
But.. uhm.. the audio is garbage.
I was wondering if I could use a lavalier microphone like this one
https://www.amazon.com/Professional-Microphone-Omnidirectional-Smartphones-Cancelling/dp/B016C4ZG74/ref=sr_1_3_sspa?ie=UTF8&qid=1520181118&sr=8-3-spons&keywords=android+lavalier+mic&psc=1
And then use it like the Shure MV88
https://www.amazon.com/Shure-Condenser-Microphone-Windjammer-Windscreen/dp/B01DIPN1V8/ref=sr_1_1_sspa?s=musical-instruments&ie=UTF8&qid=1520181150&sr=1-1-spons&keywords=shure+mv88&psc=1&smid=AJFLJ7J2AIXGD
And like, clip it on my phone. Would the audio be quiet? I need to know so I know whether or not to buy this!
Thanks!
https://linustechtips.com/topic/902453-question-about-mobile-microphone/
for 12$ you can try it now before you leave and return it if it doesn't work like you want no?
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
1 minute ago, Himommies said:
I don't recommend buying portable mics.buy portable recorders instead such as a Tascam DR-05
why are you quoting me?
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
