HTML - Parallex and slideshow mix help
Go to solution Solved by Allupyourfinger,
You should put this in the coding section
Hey i was wondering if anyone knew a way to be mix the Parallex effect with an auto slideshow effect, ive got both new working just not together.
Im using HTML (website design and image linking for slideshow) - CSS (position of the slide show on the website self/The code for the parallex)- javascript (this is used for the slideshow to run)
would i have to find a way of doing the slide show in CSS and have it under my Parallex tags?
https://linustechtips.com/topic/899014-html-parallex-and-slideshow-mix-help/
