Hi everyone.
Basically I run a small windows (not the o.s. :) ) company and we moved to a new place.
For some reason I needed my i.s.p. to bring connectivity (phone and internet) on the second floor, on the right side of the building : they said they could bring it only on the first floor, on the left side of the building. Awesome, thank you very much.
So now for the Internet access I have a ~ 40meters cat 6 cable that gives me access where I needed it, coming into a switch to split into my pcs, printers and stuff.
I thought for the phone i could simply buy a base+3 wireless devices and connect. I was wrong, it worked for a period but now for some reason it will just give me problems really often.
Now, given that at the moment it would be really really unpleasant to put a new 40meters cable for the phone, I'm looking for :
- a device for the first floor that has an rj41 input to get analogic phone calls and an rj45 ouput to make them travel through my existing internet cable (it has to act as a network device, it can't get the cable just for itself as that is currently used for my internet already!)
- a phone with rj45 plug I can connect to the network on the second floor
Is it possible to do so?
Thanks anybody
https://linustechtips.com/topic/898777-phonenetworking-problem/
There is a chance
https://www.amazon.com/RJ45-RJ11-Cable-Sharing-Kit/dp/B002DI4WYW
something like that, would work for what you want, however i believe the way these work are they split the pairs, so you would be limited to 100Mbit on your switch / internet connectivity.
https://linustechtips.com/topic/898777-phonenetworking-problem/#findComment-11068879
