AMD Phenom X4 965 memory controller issues?
Go to solution Solved by Crunchy Dragon,
Wish I had a FreeGeek near me.
Try updating the BIOS and see if it behaves any differently. Also see if all 4 DIMMs will register with the X2 550 installed.
Welcome to the forums!
Alright, so last year I bought a used desktop (AMD Phenom X2 550, Nvidia Geforce 9800GT, Gigabyte GA-MA770T-UD3P Motherboard) and a Phenom X4 965 from my local FreeGeek, and I noticed when I installed the X4 965 that I lost the functionality of two of the four DIMM slots on my motherboard. Recently, I noticed that only one DIMM slot was working properly. Could this be a bad memory controller or is it just a simple BIOS update fix?
CPU: AMD FX 4170 @ 4.7ghz Motherboard: Asus M5A97-R2.0 RAM: 11GB DDR3-1600 GPU: Asus Geforce GTX 780ti 3GB Reference Case: Cooler Master Storm Scout Storage: 1x 250GB Seagate Barracuda 7200RPM, 1x 500GB Seagate Barracuda 7200RPM, 1x 500gb Hitachi 7200RPM  PSU: Antec Earthwatts 650W Display: Dell U2410 (1920x1200 @ 60hz, 24") Cooling: Cooler Master Hyper 212 EVO, 3x 140mm Cooler Master fan Keyboard: Lenovo OEM keyboard (membrane) Mouse: Redragon Centrophorus Sound: Sound Blaster xFi sound card & Marley Good Vibrations headphones Operating System: Windows 10 1809
https://linustechtips.com/topic/885229-amd-phenom-x4-965-memory-controller-issues/
1) Yeah they sell really great stuff at mine. My friend got a GTX 950 there for $75.
2) I'm gonna try that in a couple weeks with someone who knows what they're doing. And I believe my friend has my X2 550 lying around somewhere, I'll ask him about it.
3) Thanks a bunch!
Update: both dimm slots work, it might be that my 2gb stick died. Overall system stability has gone down over the past few days, even after tweaking BIOS settings and downclocking my CPU by 100mhz
