Hey LTT
I already did a build log about this build before so this will be more of a update/showing the current state of Project WOLF.
Hardware:
i7 4790k 4.7GHz
MSI Krait Z97
Corsair 16GB 1600
Asus GTX 1080 ti strix oc
Fractal design celsius S36 AIO
Fractal design Define S case
EVGA 850W Supernova G2
Samsung/Crucial SSD's
3x Thermaltake Riing 12RGB fans (on the 360 radiator)
3x Thermaltake Riing 14RGB fans (intake fans front)
Few mods were done to this case:
Case painted
Added a aluminum Floor wrapped in carbon fiber
Added a fan grill to the front panel for extra airflow wrapped in carbon fiber
Added a vinyl/sticker design front panel
Vertical GPU mount from CM
Custom sleeved cables.
Angled the moduvents on top panel for airflow
Album for more picture: https://imgur.com/a/O5PBV
if there are any questions feel free to ask below!
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/882475-white-define-s-project-wolf/
7 minutes ago, Dutch-stoner said:
Why all the white-space below your last img?
should be fixed thx for the heads up!
Damn, it looks fantastic. Great job man!
How did you make a vertical GPU mount?
Also, could you show a picture of the cable management in the back? I just got custom cables too and, I'm in need of some inspiration.
Make sure to quote or tag people, so they get notified.
Thank you!
the GPU mount is from CM aka Cooler Master. it's called:Vertical Graphics Card Holder Kit
i don't have a picture of the cable management but il take one tomorrow, it's not that great tho :P
2 minutes ago, wildthing said:
The GPU mount is from CM aka Cooler Master. it's called:Vertical Graphics Card Holder Kit
Oh really? I thought it was only compatible with Cooler Master's cases.
How did you mount it?
your case needs at least 7pci slots and it should fit.
only thing you will need to do is cut case like so: https://imgur.com/42BcW3f
this is for your GPU monitor cables etc
PS: if you're planning on buying one make sure it comes with the pci riser cable
The one on CM's site says that it does not come with one.
Also, I'm not sure if I could fit the card since I'm using a Be Quiet Dark Rock 3.
i didn't buy mine from their site i got it from a local store and it came with a riser card.
yea it won't work with a big air cooler
