Posted January 1, 2018 Ryzen 3 1200 MSI B350M gaming pro Gtx 750ti 8gb Corsair value selcect 1x8gb EVGA 500w 80+ assembled the pc outside of the case put the ram in plugged in the 24 pin and 8pin cpu. Turned it on nothing happend no lights debug led doesn’t light up I tested the outlet and put my gpu in still nothing Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 1, 2018 2 minutes ago, SleddingInWater said: Ryzen 3 1200 MSI B350M gaming pro Gtx 750ti 8gb Corsair value selcect 1x8gb EVGA 500w 80+ assembled the pc outside of the case put the ram in plugged in the 24 pin and 8pin cpu. Turned it on nothing happend no lights debug led doesn’t light up I tested the outlet and put my gpu in still nothing Ummm maybe the gpu needs power... Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10884999 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 1, 2018 Did you turn the psu switch on? Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885012 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 1, 2018 Author 47 minutes ago, Jack Dvorak said: Ummm maybe the gpu needs power... I had the gpu from another old build it worked fine no gpu cables needed Thanks through ? 43 minutes ago, ✪ Ace said: Did you turn the psu switch on? Yep Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885013 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 1, 2018 8 minutes ago, SleddingInWater said: Ryzen 3 1200 MSI B350M gaming pro Gtx 750ti 8gb Corsair value selcect 1x8gb EVGA 500w 80+ assembled the pc outside of the case put the ram in plugged in the 24 pin and 8pin cpu. Turned it on nothing happend no lights debug led doesn’t light up I tested the outlet and put my gpu in still nothing How are you turning it on? Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885017 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 1, 2018 Just now, ✪ Ace said: How are you turning it on? 9 minutes ago, SleddingInWater said: Ryzen 3 1200 MSI B350M gaming pro Gtx 750ti 8gb Corsair value selcect 1x8gb EVGA 500w 80+ assembled the pc outside of the case put the ram in plugged in the 24 pin and 8pin cpu. Turned it on nothing happend no lights debug led doesn’t light up I tested the outlet and put my gpu in still nothing I’m guessing the cpu isn’t seated correctly... you lined t up and put the pins in rightly right? Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885020 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 1, 2018 Author 41 minutes ago, ✪ Ace said: How are you turning it on? I don’t have the power switch plugged in I have it outside of the case I switch on the psu no lights no fans spin 40 minutes ago, Jack Dvorak said: I’m guessing the cpu isn’t seated correctly... you lined t up and put the pins in rightly right? I think I set the triangle up but I’ll take it apart right now Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885022 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 1, 2018 Solution you have to short the pins with a screwdriver. You cant just turn the psu on Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885031 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 1, 2018 You have to use your screwdriver to short out the power sw pin on the Front Panel header pins to turn it on. Also try pluging the display into the GPU Desktop: Intel Core i5 7600K @ 3.7GHz, 8GB x 2 GSkill Ripjaws, Gigabyte Gaming B8 Motherboard, 256GB Samsung 960 Pro PCIe NVMe SSD, 1.27 TB of Spanned Goodness, GTX 1050 Ti, and GT 710. Runs both macOS High Sierra and Windows 10, and Pop! OS 20.04 LTS. Laptop: Lenovo X1 Carbon 2nd Gen Server: 7TB Array in Proxmox server Intel Pentium G4560 @ 3.5GHz 16GB DDR4 ASUS H270M Motherboard 1GB Zotac NVIDIA GT 710 Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885033 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 1, 2018 Author How do I do that? I see the power pins 38 minutes ago, elin13 said: You have to use your screwdriver to short out the power sw pin on the Front Panel header pins to turn it on. Also try pluging the display into the GPU Thanks I will Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885039 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 1, 2018 2 minutes ago, SleddingInWater said: How do I do that? I see the power pins Desktop: Intel Core i5 7600K @ 3.7GHz, 8GB x 2 GSkill Ripjaws, Gigabyte Gaming B8 Motherboard, 256GB Samsung 960 Pro PCIe NVMe SSD, 1.27 TB of Spanned Goodness, GTX 1050 Ti, and GT 710. Runs both macOS High Sierra and Windows 10, and Pop! OS 20.04 LTS. Laptop: Lenovo X1 Carbon 2nd Gen Server: 7TB Array in Proxmox server Intel Pentium G4560 @ 3.5GHz 16GB DDR4 ASUS H270M Motherboard 1GB Zotac NVIDIA GT 710 Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885053 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 Author 6 minutes ago, SleddingInWater said: I think I set the triangle up but I’ll take it apart right now Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885067 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 30 minutes ago, SleddingInWater said: Yeah that is good... make sure you use thermal compound and put the cooler back on Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885092 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 Author 2 minutes ago, Jack Dvorak said: Yeah that is good... make sure you use thermal compound and put the cooler back on Done Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885108 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 Were you able to get it to boot? Desktop: Intel Core i5 7600K @ 3.7GHz, 8GB x 2 GSkill Ripjaws, Gigabyte Gaming B8 Motherboard, 256GB Samsung 960 Pro PCIe NVMe SSD, 1.27 TB of Spanned Goodness, GTX 1050 Ti, and GT 710. Runs both macOS High Sierra and Windows 10, and Pop! OS 20.04 LTS. Laptop: Lenovo X1 Carbon 2nd Gen Server: 7TB Array in Proxmox server Intel Pentium G4560 @ 3.5GHz 16GB DDR4 ASUS H270M Motherboard 1GB Zotac NVIDIA GT 710 Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885116 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 Author 21 minutes ago, ✪ Ace said: you have to short the pins with a screwdriver. You cant just turn the psu on THANKS works Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885133 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 Author 3 minutes ago, elin13 said: Were you able to get it to boot? Yes thank you! Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885135 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2018 8 minutes ago, SleddingInWater said: Yes thank you! This is why I love the LTT community Link to comment https://linustechtips.com/topic/880395-help-pc-not-posting-fixed/#findComment-10885173 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
