I have compatibility questions about the products listed below, I am looking to upgrade my mobo and cpu.
"Intel Core i7-7700K Kaby Lake 4.2 GHz LGA 1151 Boxed Processor" (does this come with a stock cooler? ) ( and will it be compatible with 4x  16GB  DDR3/1600MHz Corsair XMS 3 ram? )
"Gigabyte GA-H270-Gaming 3 LGA 1151 ATX Intel Motherboard" ( Same question as above with the ram )
Last but not least My current mobo / CPU is a  ( GIGABYTE GA-Z77X-DH3 ) and ( i5-3570k ) that i will be switching out.  I have what I believe is a corsair liquid cooler over the CPU with tubes to 2 fans on the top. I am not sure of the exact model but i believe it is 120mm fans. Will this also be compatible with this upgrade?
Sorry for the drawn out question, I hope you are able to help so I can make the right purchase.
https://linustechtips.com/topic/872038-cpu-mobo-upgrade-help/
no you will need ddr4 ram an intel i7-7700k is best to pair with an z board(you can overclock an k cpu only on a z board) if you don't want to overclock get an i7-7700k with the same board the i7-7700k will not come with an stock cooler an i7-7700 will come with an stock cooler
ask me about your system builds, AIO's, CPU's, PSU's, and GPU's.
https://linustechtips.com/topic/872038-cpu-mobo-upgrade-help/#findComment-10810623
oke so you have a 240mm rad on your current build how old is that one and what are the materials its made from?
https://linustechtips.com/topic/872038-cpu-mobo-upgrade-help/#findComment-10810629
picture is worth 1000 words if you can post a picture we will have a better idea of what cooler you have.
As for the motherboard what the previous person was trying to say is unless you get a z270 motherboard it's pointless to buy a 7700k since the K means unlocked for overclocking and H270 does not let you overclock. So you mind as well buy a i7-7700 cpu instead if you planning to buy the H270 board.
Going back to the cooler, if its a corsair h100i All in One liquid cooler. it might work with the new board. I am not sure if the mounting bracket changed.
https://linustechtips.com/topic/872038-cpu-mobo-upgrade-help/#findComment-10810675
I was able to find the exact model. It is the Asetek 570LX Liquid Cooling System w/240MM Radiator and Dual Fans.
So the "Gigabyte Z370 HD3 LGA 1151 ATX Intel Motherboard" Would be a better option in teams of overclocking?
Also would you be able to suggest new compatible ram,  and if the cooler is not as well.
https://linustechtips.com/topic/872038-cpu-mobo-upgrade-help/#findComment-10810685
Thank you for the help so far I have decided against getting the i7-7700K since I have just learned about the release of coffee lake. I have checked myself and everything is compatible. And as you said above the Z sires motherboard will be able to allow overclocking if I am correct.
So this will be the upgrade with the needed ram added.
"Intel Core i5-8600K Coffee Lake 3.6 GHz LGA 1151 Boxed Processor"
"Crucial Ballistix Elite 16GB 2 x 8GB DDR4-2666 PC4-21300 CL16 Quad Channel Desktop Memory Kit"
If you could please get back with me. All I need to know before closing the thread is if the ( Asetek 570LX Liquid Cooling System w/240MM Radiator and Dual Fans ) will be compatible with the new build, Thanks :)
https://linustechtips.com/topic/872038-cpu-mobo-upgrade-help/#findComment-10811014
