i have the asus crosshair vi hero.
it has 3 pci slots.
i am thinking of getting the meshify c. and id  like to put the gpu on the bottom pci slot.
i saw online that it has a PCIe 3.0 x16 (CPU): 2 (x16/x0, x8/x8) on the asus board.
im not very familiar with that x16/x8 meaning. but im assuming its half of the performance. however for gaming would it be a huge difference in performance?
or is there a way to disable the top lane to make the middle or bottom lane to run x16?
thanks in advance
https://linustechtips.com/topic/871055-pci-slots-question/
Just now, ShredBird said:
There is not a significant deterioration of performance using x8 instead of x16.  You may be able to set the speed in the BIOS/UEFI or it may auto configure based on how many devices are present, just depends.
thank you!
https://linustechtips.com/topic/871055-pci-slots-question/#findComment-10801958
