i5-4690k i5-4690k Help!
Solved by 79wjd,
How many volts are you putting to the CPU? As long as it's <= 1.30v~ then it's fine. Based on your temps, i'm going to guess you're around 1.15v~, so...fine.
Doctah ·
Posted in Peripherals0 -
2
michaelb198 ·
Posted in Peripherals1 -
errorcode123_dindin1 ·
Posted in Graphics Cards2 -
Packhunter ·
Posted in Graphics Cards3 -
12
6
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies4
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
