What's your budget, and what are the lowest settings you're comfortable playing at, and your resolution?
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
https://linustechtips.com/topic/862158-help-me-choose/#findComment-10721144
10 minutes ago, Abraham Martinez said:
@JaegerBThank you for responding! My budget is $600 USD and the lowest setting i am comfortable playing at is low. As for the resolution it is 1360 x 780 (playing on television)
That 1050 Ti will be alright on most AAA games, around Medium, even high. What you should be upgrading is RAM, CPU, and mobo. Used parts are real good. A skylake or maxwell cpu these days is really cheap second hand, and you might even be able to get mobo and ram with it. You probably want DDR4 8GB at 2133 or 2400 depending on what you can afford. Have a look around craigslist, ebay, all that stuff.
I mean, you can get around 40-50 fps on medium in BF1 with what you have right now. You don't even really need to upgrade. If anything, save your cash and overhaul your rig some time in the future.
My PC:
https://linustechtips.com/topic/862158-help-me-choose/#findComment-10721169
You should really upgrade your mobo cpu and ram, the 1050ti is a pretty new piece of hardware so upgrading your graphics card is redundant with a 1st gen cpu.
Also if that hardrive of yours is old, you might want to consider getting a new one or even an SSD to prevent from an old HDD to slow down your build.
Here is an example of what would be a good upgrade below.
Ryzen 1600 ~ 200$
AM4 Mobo ~ 100$
16 GB Ram~ 170$
2TB HDD~ 70$
https://linustechtips.com/topic/862158-help-me-choose/#findComment-10721209
Hey Mate,
Here:
1. Corsair LPX - 8GB (2x4GB) - $135 -https://www.amazon.ca/Corsair-Vengeance-3000MHz-Desktop-Memory/dp/B0123ZB70Q/ref=sr_1_1?ie=UTF8&qid=1511156524&sr=8-1&keywords=corsair%2Blpx&th=1
2. Mobo: MSI x370 -$160 - https://www.amazon.ca/MSI-X370-Motherboard-GAMING-PLUS/dp/B06XQ5V3R4/ref=sr_1_5?ie=UTF8&qid=1511156504&sr=8-5&keywords=x370+motherboards&dpID=515-GjHPpyL&preST=_SX300_QL70_&dpSrc=srch
3. Processor - i5 8400 - $250 - https://www.ncix.com/detail/intel-8th-gen-core-i5-8400-3d-142465.htm
4. Monitor - BenQ - $100 - https://www.amazon.ca/BenQ-9H-LE5LB-QPA-21-5-Inch-LED-Lit-Monitors/dp/B019EFMK1I/ref=sr_1_3?s=electronics&ie=UTF8&qid=1511156873&sr=1-3&keywords=1080p+monitor&dpID=41kMwLTjZnL&preST=_SX300_QL70_&dpSrc=srch
This totals $645 If you can buy a used monitor or ram then sweet.
Alternatively you could swap out the i5 processor for:
 i3 8100 - $160 - https://www.ncix.com/detail/intel-8th-gen-core-i3-8100-dc-142463.htm
this will save you $90 and give you $40 to put back into a better monitor perhaps :) or more ram. Or forget about the new monitor if you don't watn 1080P and you save yourself another 100$ (i would recommend saving and going for a 1440p or a 1080p with 100+ refresh rate monitor, it makes a big difference. or if you are satisfied, save yourself the money all together :) )
https://linustechtips.com/topic/862158-help-me-choose/#findComment-10721265
