Commander PRO USB Hub Help!
Hello! I need some help with drivers for the Commander PRO. As I am sure most will know it connect to USB 2.0 herader on your motherboard to communicatre to Corsair LINK and to utiliize the 2 USB headers on the PRO. My problem is the USB Hub driver in Windows 10. I am currently running and H100i V2 and want to monitor with the Corsair LINK. On my Z270G Asus ROG Strix Mobo i have 2 USB 2.0 headers that work perfectly! They both allow corsair LINK to see and make changes to the Commander PRO and my H100 is functioning perfectly on. The USB hub driver is giving me the following error.... Windows has stopped this device because it has reported problems. (Code 43)... I have performed the following steps to resolve my problem
uninstalled and reinstalled the device using the manager
Updated BIOS and all drivers to the most current driver state
Disable USB Selective Suspend in power management
Disable USB Selective Suspend to the device itself in Device Manager>properties>power management.
Had a replacement sent via RMA from Corsair
Removed power supply from mother board and CMOS battery for reset. (this resulted in a new error but reverted on a subsequent restart....error 31)
Disconnected all other devices being powered by SATA on MOBO
All steps have resulted in the same problem. I would suspect my motherboard except the EVERYTHING else works perfectly on both headers. Does anyone out there have an idea that I may not have thought of yet?
Thank you in advance!
Corsair Air 240
Intel Core i5-7600k
Corsair H100i V2
ASUS ROG STRIX Z270G Gaming
2 x 8GB Corsair Vengeance LPX
Samsung 960EVO 256GB M.2
WD Blue 1TB
Gigabyte GTX1080 G1
Corsair CX750M
https://linustechtips.com/topic/838873-commander-pro-usb-hub-help/
  • 10 months later...
