Motherboard: ASUS Strix z270e
Whenever I try to place my CPU (i7-7700k) into the socket (with a little plastic "CPU installation tool" that comes with the ASUS motherboard), when I get to the point of pushing down the socket lever arm about 90% of the way the mounting bracket sort of "jumps"/"pops" (too much tension/pressure on the mechanism?). The CPU is aligned properly (arrow on the bottom left), and from what I can visually tell, is sitting snugly inside the socket (e.g. corners match up).
Rather  perplexing to me is that nothing seems to be visually broken o_o, and that it had worked OK on previous occasions (not my first time putting this CPU & mobo together).Is it RMA time >_<?
https://linustechtips.com/topic/835712-problem-with-a-cpu-mounting-clamp/
are you clamping doen the socket with the tool still on? the plastic square is just to make it easier to line up the cpu correctly and must be removed when the cpu is places into the socket before clamping it down or you risk damage
Have you tried to perform a sudden temporary interrupt of the electricity flow to your computational device followed by a re-initialization procedure of the central processing unit and associated components?
Personal Rig Specs
CPU: Intel Core i7-7700K @ 4.8GHZ
Motherboard: Asus ROG STRIX Z270H GAMING
Graphics Card: Inno3D ICHILL GEFORCE GTX 1080 TI X3 ULTRA
RAM: Corsair Vengeance LPX Black DDR4 2x8GB @ 3GHZ
Storage: 2 x Samsung NVMe SSD 960 EVO 256GB in Raid | 2 x Seagate 4TB Expansion Desktop
(seagates are originally external drives removed from casing and installed internally)
PSU: Seasonic Prime Titanium 850W
Case: Mission SG GGX 3.5 (same as Rosewill Cullinan or Anidees AI Crystal with other stock fans)
Cooling: Kraken X62 for CPU, Corsair H55 with NZXT Kraken G12 for GPU
That's news to me; I've been clamping it down previously (and successfully) with the plastic installation-tool still on o_o.
Also, the installation process in the motherboard manual shows the tool still in place after the end of the installation process.
huh.. a bit of googling reveals that it seems you can leave it on, though i never used it myself as slotting the cpu into the socket isn't that hard, and isn't less dangerous or damaging unless you hold it on the pins itself or aren't grounded.
i also had a customer which had somehow managed to get the installation tool squeezed between the cpu and clamp in a way that requires recessive amounts of force, so i always thought it awas just a "newbie" helping tool to guide correct cpu placement.
the cpu installation tool is something that has been included by some motherboard manufacturers lately, not by Intel or AMD..
i would just remove the plastic tool and let the cpu sit by itself in the socket.
Personal Rig Specs
