PHP need help with a few things
Go to solution Solved by Mr_KoKa,
you read 128 bytes from socket, so even your example (295) will be fragmented and read after 3 fgets.
Hello,
I have a few things I need help with.
How do I put everything from @ to the first space in a string to a new string? then how do I turn that string into a array where each key=variable is separated with ; until last which is not separated and ends with = or =something.
Thats it for now :P
Back-end developer, electronics "hacker"
https://linustechtips.com/topic/825556-php-need-help-with-a-few-things/
For the first part, you use explode()
$email = 'username@domain.com';
$e = explode("@",$email)[0];
echo $e;
output
Quote
username
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
echo $e;
output
Oh, string will start with a @ so there is nothing in front of it
@badges=moderator/1;color=#008000;display-name=joveice;emotes=;id=5e290206-79cf-45cc-83da-8d49a26fc152;mod=1;room-id=170536778;sent-ts=1503421860968;subscriber=0;tmi-sent-ts=1503421858315;turbo=0;user-id=30332954;user-type=mod :joveice!joveice@joveice.tmi.twitch.tv PRIVMSG #digitalarcbot :dassa
@ is the start, I need everything behind into variables, where ; separates them and it stops at " ". Notice there is no ; at the last one.
Use a regex!
<?php
    /* Regex Explanation
     * ([^=@;]+) matches all charachter except '=@;'
     * Example: badges
     * then 'a' = is required
     * ([^[:space:];]+)? matches everithing except 'space' and ';' one or 0 times
     * Example: moderator/1
     * Full Match => badges=moderator/1
    $regex = '/([^=@;]+)=([^[:space:];]+)?/';
    $str = '@badges=moderator/1;color=#008000;display-name=joveice;emotes=;id=5e290206-79cf-45cc-83da-8d49a26fc152;mod=1;room-id=170536778;sent-ts=1503421860968;subscriber=0;tmi-sent-ts=1503421858315;turbo=0;user-id=30332954;user-type=mod :joveice!joveice@joveice.tmi.twitch.tv PRIVMSG #digitalarcbot :dassa';
    /* Preg Match */
    preg_match_all($regex, $str, $matches, PREG_SET_ORDER, 0);
    /* Get as key->value array, this will ignore rows where the value is not set */
    $array = array_column($matches,2,1);
Working example: https://repl.it/KUpk/2
Business Management Student @ University St. Gallen (Switzerland)
HomeServer: i7 4930k - GTX 1070ti - ASUS Rampage IV Gene - 32Gb Ram
Laptop: MacBook Pro Retina 15" 2018
Operating Systems (Virtualised using VMware): Windows Pro 10, Cent OS 7
Occupation: Software Engineer
$s = '@badges=moderator/1;color=#008000;display-name=joveice;emotes=;id=5e290206-79cf-45cc-83da-8d49a26fc152;mod=1;room-id=170536778;sent-ts=1503421860968;subscriber=0;tmi-sent-ts=1503421858315;turbo=0;user-id=30332954;user-type=mod :joveice!joveice@joveice.tmi.twitch.tv PRIVMSG #digitalarcbot :dassa';
$spacePos = strpos($s, ' ');
if($spacePos !== false){
  $s = substr($s, 1, $spacePos - 1); // Skipping first character (@) and not including found space
  $vars = explode(';', $s);
  $keyValue = array();
  foreach($vars as $var){
    $parts = explode('=', $var);
    if(count($parts) == 2){
      $keyValue[$parts[0]] = $parts[1];
    } else {
      echo 'Invalid variable: '.$var;
  var_dump($keyValue);
} else {
  echo 'Space not found.';
I used strpos to find first space and then substr to skip @ and extract string to the position of the space found. then I just explode string by ; and then each by =
Result is associative array. You can enclosure it into a function and instead of echoing errors return false or throw exceptions. Here is working example: https://repl.it/KUo7/0
Currently experiencing issues with the data (the string) getting split up for some reason. I var_dump it after it's grabed from the socket, and it spits out 3 strings... it did not do that before, and why on earth does it do that...
<?php
//So the bot doesn't stop.
set_time_limit(0);
ini_set('display_errors', 'on');
echo 'boot';
//Example connection stuff.
$config = array(
    'HOST' => 'irc.chat.twitch.tv',
    'PORT' => 6667,
    'AUTH_NICK' => 'nickname',
    'AUTH_PASS' => 'oauth:xxxxxxxxxxxxxxxxxxx',
    'CHANNEL' => 'channeltojoin'
class IRCBot {
    private $configarray = array(
            'PORT' => 6667,
    //This is going to hold our TCP/IP connection
    var $socket;
    //This is going to hold all of the messages both server and client
    var $ex = array();
     Construct item, opens the server connection, logs the bot in
     @param array
    function __construct($config)
        $this->socket = fsockopen($config['HOST'], $config['PORT']);
        $this->login($config);
        $this->send_data('JOIN', '#'.$config['CHANNEL']);
        $this->send_data('CAP REQ ', ':twitch.tv/membership');
        $this->send_data('CAP REQ ', ':twitch.tv/commands');
        $this->send_data('CAP REQ ', ':twitch.tv/tags');
        $this->main();
     Logs the bot in on the server
     @param array
    function login($config)
        $this->send_data('PASS', $config['AUTH_PASS']);
        $this->send_data('NICK', $config['AUTH_NICK']);
     This is the workhorse function, grabs the data from the server and displays on the browser / aka cmd window
    function main()
        $data = fgets($this->socket, 128);
        echo $data;
        $this->ex = explode(' ', $data);
        if ($data[0] == '@') {
            $s = $data;
            if ($spacePos !== false) {
                foreach ($vars as $var) {
                    if (count($parts) == 2) {
                if (isset($this->ex[3])) {
                    $command = str_replace(array(chr(10), chr(13)), '', $this->ex[3]);
                    if ($keyValue['user-type'] == 'mod') {
                        switch ($command) //List of commands the bot responds to from a user.
                            case ':!mod':
                                $this->write('o mod power');
                                break;
                    switch($command) //List of commands the bot responds to from a user.
                        case ':!hello':
                            $this->write('everyone can call me!');
                            break;
        } elseif ($this->ex[0] == 'PING :tmi.twitch.tv') {
            $this->send_data('PONG :tmi.twitch.tv', $this->ex[1]); //Plays ping-pong with the server to stay connected.
        flush();
        usleep(100000);
        $this->main();
    function send_data($cmd, $msg = null) //displays stuff to the broswer and sends data to the server. / aka cmd window
        if($msg == null)
            fputs($this->socket, $cmd."\r\n");
            echo '> '.$cmd;
        } else {
            fputs($this->socket, $cmd.' '.$msg."\r\n");
            echo $cmd.' :'.$msg;
    function write($msg = null) //send message to channel
        if(!$msg == null)
            $cmd = 'PRIVMSG #'.$this->configarray['CHANNEL'];
            fputs($this->socket, $cmd.' :'.$msg."\r\n");
            echo '> '.$cmd.' :'.$msg;
	$bot = new IRCBot($config);
@Mr_KoKa
Yes I know it got 2 config arrays but I had issues with it not accepting the first one later in the script and the one inside the class at the start and visa versa
And it's messy.
7 minutes ago, Joveice said:
<?php
set_time_limit(0);
echo 'boot';
$config = array(
    'PORT' => 6667,
class IRCBot {
            'PORT' => 6667,
    var $socket;
    var $ex = array();
     @param array
        $this->main();
     @param array
    function main()
        echo $data;
            $s = $data;
                            case ':!mod':
                                break;
                        case ':!hello':
                            break;
        flush();
        usleep(100000);
        $this->main();
        if($msg == null)
            echo '> '.$cmd;
        } else {
        if(!$msg == null)
@Mr_KoKa
And it's messy.
Jupp, I'll have to redo the code, something is really wrong. I just restarted the script and it worked, restarted it again and it dident work..
