I now have a blue yeti pro, and it worked fabulously during it's first 2 weeks, I haven't dropped it or anything, then all of a sudden it just started picking up a large static noise, like everything isn't clear, even if I use a headset on the jack underneath the mic it sounds really horrible, is there anyway to fix this?
and it has this constant pick up
https://linustechtips.com/topic/817736-blue-yeti-pro-problem-help/
Try turning it's  input volume down on the mic and in Windows
CPU: Intel Core i7 8700
GPU: Gigabyte GeForce GTX 1070
MOBO: ASUS Z370-F STRIX
RAM: 16GB Corsair Vengeance DDR4 2133MHz
Just now, alienmer said:
Thanks for the reply, I tried it too, but I can hear myself muffled and there's static all over with the recordings or playback
Try different USB ports. What motherboard do you have? If it doesn't have good electrical guards, electrical noise can interfere with the signals.
I'm trying it out on different computers too right now, port 1.0, 2.0 and 3.0 and the static muffles are still there, the main pc I use has is a h1z0 pro gaming asus motherboard.. but I think I got it now actually! When you said I go to the volume adjustments I noticed my default playback was on blue yeti pro, I'm baffled that there's a "blue yeti pro" right there on my playback devices.. then I set my default device back to my speakers and everything is fine again! thanks for the info with the electrical guards too!
