Hlw linus i have a problem. i have a western digital blue internal 1 tb hdd. few month ago it crashed after installing windows 10. then when i try to re use it by formating from disk management  is says "Disk is write protected" i also try to fix the problem by using HDD HDD Regenerator it says  " Master Boot Record of This Hard drive is Damaged !"
Please Help me that how can Restore MBR to the Hard disk or others way . i attached some screenshot below .
Thank You :)
https://linustechtips.com/topic/808579-mbr-crash-fix/
