I built my computer earlier this year and I decided to add RGB lights later during the year. As I was watching through some videos I came across this one that stated you needed to purchase a converter cable otherwise the wrong voltage would be sent to the lights and it could damage it or worse. I was hoping to have some clarity on that because my motherboard supports Asus Aura and when I bought a basic LED strip it plugged into the motherboard and the lights worked fine. I didn't need to cut any wires and plug them into the power supply, I forgot what the port was referred to as, but I connected the LED strip directly into the motherboard. It did feel a little warm after a bit, so I unplugged it just in case. Is this something I should be worried about? Is there anything else I need to know prior to installing RBG LED strips? Which would you recommend?
Case: Corsair Obsidian Series 750D Airflow Edition, Full Tower ATX Case
Motherboard: ASUS ROG Maximus IX Hero LGA1151 DDR4 DP HDMI M.2 USB 3.1 ATX Motherboard
Basic LED strips I used: https://www.amazon.com/gp/product/B01EFEUZPQ/
Video I saw (with timestamp):
https://linustechtips.com/topic/806105-adding-rbg-lights-to-case/
Most RGB strips are 12V, which is what the motherboards use. As long as the strip uses the same connector as the motherboard it will be compatible.
If you use too long strips (or too many) you could draw more current than the circuit on the motherboard is rated for blowing it up. The motherboard should specify what it is rated for (potentially in the useless unit of metres, as LED wattage and light densities vary from strip to strip). I would recommend either cutting the strip to the minimum size required for your case , or using a dedicated controller or repeater for the LEDs.
Thanks! Very useful to know. I'll likely cut the strip since it's 5 meters. That likely explains why it was getting warm.
5 minutes ago, OddsCrazyStuff said:
If you are worried, Asus lists some products that are guaranteed to work: https://www.asus.com/campaign/aura/us/Sync.html
I'll definitely keep that in mind. Thanks for the recommendation! Hoping they have some discounted on Amazon today.
I have the Crosshair hero VI x370 it has 2 RGB headers and they recommend no more than 2 meters I have 2 small strips in my case and my desk has 2 meters on the 2nd header and I've had no problems and they are synced with the board and my GPU with great affect, and yes I get an extra 100Mhz of additional performance from them:)
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
Just got around to cutting the strip to about 2 meters I believe and got everything to work. Thank you!
