"Over Current on USB Device"
Go to solution Solved by Piggy,
Something was shorting the ports on the bottom of the board even though it was sitting on cardboard... It's working now, just need to get it back in the case and hope it doesn't happen again
Looked online, only answers I could find to this error is to unplug the front USB header cables, which I did, and it did not solve the issue.
Getting this specific error: "over current have been detected on your usb device!!
system will shutdown after 15 seconds to protect your mainboard!!"
full parts list to the build is here: https://pcpartpicker.com/list/gkRDd6
PSU is a Sparkle 550w that came with the server case
Any help would be greatly appreciated
PC Specs:
New Compact Build
CPU: i7 8700k (Delidded)  |  GPU: EVGA GTX 1070Ti ACX 3.0 Black  |  Motherboard: ASRock Fatal1ty Z370 Gaming  |  Case: EVGA Hadron Air
RAM: Corsair Vengeance LPX 16GB DDR4 3000MHz  |  SSD: Samsung 860 EVO 1TB  |  Monitor: ASUS PB287Q
     OS: Windows 10  |  Keyboard: Corsair Strafe RGB  |  Mouse: Logitech G502 Proteus  |  Headphones: Steelseries Arctis 5
Surface Book 2 15"
CPU: i7 8650U  |  GPU: GTX 1060M  |  RAM: 16GB DDR3
https://linustechtips.com/topic/801140-over-current-on-usb-device/
Usb device?
visually inspect all your usb ports, externally and internally, it's usually a short inside the usb plug where the pins come loose.. my usual fix if its a usb on the case is to forcefully rip out the pins with needlenose pliers so it no longer shorts and no longer can be used, and tape over it. if its on the motherboard, you might be able to disable that usb port in the biosyou should also try to seperate any short you can see (pins touching eachother, pins touching the metal around the plug etc)
Have you tried to perform a sudden temporary interrupt of the electricity flow to your computational device followed by a re-initialization procedure of the central processing unit and associated components?
Personal Rig Specs
CPU: Intel Core i7-7700K @ 4.8GHZ
Motherboard: Asus ROG STRIX Z270H GAMING
Graphics Card: Inno3D ICHILL GEFORCE GTX 1080 TI X3 ULTRA
RAM: Corsair Vengeance LPX Black DDR4 2x8GB @ 3GHZ
Storage: 2 x Samsung NVMe SSD 960 EVO 256GB in Raid | 2 x Seagate 4TB Expansion Desktop
(seagates are originally external drives removed from casing and installed internally)
PSU: Seasonic Prime Titanium 850W
Case: Mission SG GGX 3.5 (same as Rosewill Cullinan or Anidees AI Crystal with other stock fans)
Cooling: Kraken X62 for CPU, Corsair H55 with NZXT Kraken G12 for GPU
PC Specs:
New Compact Build
Surface Book 2 15"
wait.. what? could you take a picture of your setup please?
Personal Rig Specs
