Hi,
I recently got my CPU overclocked stable so I decided to do my GPU. I have a VTX3D HD 7870 Black Boost Tahiti 2GB.
I read a few guides on overclocking so I used Afterburner to increase the core mhz by 25 and run Valley Benchmark on Extreme HD. I noted down all the score and I managed to get to 1200mhz (originally 975mhz) before it started to freeze/black screen/restart.
So I moved it back to to what I thought was a stable overclock but for some reason my reading are now failing or the FPS is down at 4-8FPS. Even when I revert Aftermarket back to stock and re-run the benchmark it still gives really low FPS.
Am I missing something or is this common?
Thanks
AMD Ryzen 5600X | MSI Tomahawk B550 | Corsair H100i Elite Capellix AIO | NVIDIA 3070ti FE | Corsair Vengeance PRO RGB 16GB 3600MHz | Corsair RM750 PSU | WD Blue SN550 1TB M.2 | WD Blue SN550 2TB M.2 | Corsair iCue 4000X RGB Tempered Case | Yamaha HS5 Active Speakers | Scarlett 2i2 Audio Interface |
https://linustechtips.com/topic/791734-hd7870-overclocking-questions/
