hi there so I recently bought myself an steelseries rival 700 and I installed the steelseries engine, as I opened the app it reckognised my new mouse, and it say "important update!"
so I clicked to update the software of the mouse an the mouse itself started to flash blue, at the end it sayd "failed to update the software" and basically the mouse was bricked in update mode, so I attached my good old logitech g402 and... nothing! it was bricked aswell! so I restarted my pc, still bricked !!! I even detached all mouses and attached an old lenovo mouse and still nothing !!! I just did a clean install, everything was working fine until this, ive searched the web and there are other cases such as mine put dont describe that all of their mouse inputs are bricked, I went into device manager and took a photo
help would be grateful
thanks in advance
 ps I can still use my keyboard though so I am able to perform any action but without mouse input
3x 128GB Samsung PM961 M.2 (2x Kryom PCI-E M.2 by Aqua Computer) on windows os raid and 1x PM961 as os Host on the motherboard m.2 slot
+ 250GB Samsung 850 EVO
+ 7200RPM Seagate 1 Terabyte HDD
  • PSU
    seasonic 750 prime platinum Active PFC F3
  • Cooling
    Noctua NH-D15S (original fan replaced by an Noctua 140mm industrialPPC-2000 IP67 PWM + Steel 140mm fan guard)
  • Keyboard
    Cherry MX Board 6.0 ISOANSI + Vector/Tai keycaps+ Landing pads + O-rings
  • Mouse
    BenQ Zowie EC2-A White Edition
  • Sound
    Edirol Roland UA-25EX + Beyerdynamic DT 770 Pro
  • Operating System
    Windows 10 x64 (Enterprise) SP1, OpenSUSE, Remnux
https://linustechtips.com/topic/782358-mouse-input-disabled-by-steelseries-engine/
up
  • PSU
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
nvm i figured it out
had to go in safe mode delete usb mouse drivers with another "basic NON gaming mouse"
deinstall steelseries engine
reboot normal
reinstall steelseries engine
reupdate steelseries r700
and voila
worked for me :D
  • PSU
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
