Hey everyone, I've got the Rosewill Thor V2 and wanted to replace the mesh on the side panel with plexiglass or any other material if you have some suggestions. But I was looking on amazon for plexiglass and couldnt think of what thickness to get that wouldn't be to bulky, but also so thin that it would warp and bend once it's attached. And if possible im looking to stay below $50 since what I saw on amazon was definitley on the pricier side. Of course all help is apperciated!
https://linustechtips.com/topic/781793-replacing-mesh-side-panel-with-window/
Double sided tape and check your local hardware store for plexi
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
Glass is cheaper. Way cheaper than plexiglass. I called my local glass place and had them custom cut 3 pieces of glass for my case. Each piece cost ~ $20. I highly recommend you measure your dimensions and check around for a local glass shop. This also afford you the opportunity for smoked glass, smoother edges if you want, and you can use foam tape just the same as plexi. 1/8" is plenty thick, I agree with @intender.
