Hello,
I have a gaming pc that is very capable of running AAA games at 4k (i7, 1070, 16gb ram, etc). Yet my 4k monitor only has one input, which is display port. I want to be able to use my xbox one on that monitor. The xbox one only has hdmi output, so I need an ACTIVE hdmi > display port adapter. Yet all that I am finding is display port > hdmi. I don't want to buy one of them and not have it work as it is intended for a display port input and output to a hdmi display. Yet I need it the other way around. I don't want to use the xbox streaming app, I want it to display directly off the 4k monitor (yes I know it only outputs 1080). Does anyone know of any way to know if an adapter will work in reverse or know of an adapter that is intended for display port input and hdmi output that is still an active adapter?
https://linustechtips.com/topic/781493-need-help-with-adaptor/
What's the difference between an active and normal adapter?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/781493-need-help-with-adaptor/#findComment-9853124
Just now, iTech said:
Active would mean there is "active" conversion circuitry inside the adapter which typically makes them more expensive and only work one way.
Is it better? And I'd think there'd be one, as they have adapters for pretty much anything.
Mouse: EVGA X17
https://linustechtips.com/topic/781493-need-help-with-adaptor/#findComment-9853163
It's not any better the active part is usually just needed for different standards. For example DVI carries a VGA signal, also HDMI pretty much DVI with a smaller connector and can't carry audio. HDMI and DP have no relation, so there is a need to actively convert the video signal. Not really any better or worse. As far as resolving the question, have a look here... click click click
https://linustechtips.com/topic/781493-need-help-with-adaptor/#findComment-9853199
