Headphone/microphone combo input
Go to solution Solved by jools,
don't bother most mobo,s come with separate mic/speaker sockets
just get an adapter from ebay
example probably cheaper out there
https://www.amazon.co.uk/d/Cables/CABSTONE-M04-Jack-4pin-socket-3pin-plug/B019VITHAA
Hello everyone,
I'm planning on building a new PC soon (my first build), and one of the thing that disturbing me with the current one is that I can't plug my headphones, which also have a microphone and only one cable to my PC and use both the microphone and the headphones with the same one.
Anybody know what input should I look for in the motherboard so I'll have a headphone/microphone input?
Thanks in addition!
Idan
https://linustechtips.com/topic/778643-headphonemicrophone-combo-input/
47 minutes ago, IamIdan said:
Hello everyone,
Thanks in addition!
Idan
use a specific motherboard for that
