Hey! So I bought this raspberry pi 3 model b just to stream live tv. But there is huge buffering issue which renders the entire thing unwatchable. I am running 100/100 network connection so I do not believe its creating a problem. My osmc is updated to the latest version. I have tried to fix it through an advance setting pluggin and by accessing the files through putty.
https://linustechtips.com/topic/776711-raspberry-pi-3-model-3-pvr-buffering-issues/
11 minutes ago, charrst said:
I had the same issue when I started using it. Go to the streaming settings (should be a little gear or similar when you click on the video stream) and disable deinterlacing.
Although I turned it back on a few months later and everything worked fine, so this could have just been a coincidence.
Can't seem to find the setting. I have the standard osmc skin
3 minutes ago, charrst said:
Yeah. I'm not entirely sure if your video is even interlaced, in which case changing that setting certainly wouldn't make a difference.
FYI its pvr streaming through simple iptv. I am streaming greek channels but what I was speculating is that the host is the issue and there is "nothing" wrong on my end. Is there anyway else I could set it up to buffer for a minute ahead and then start the stream?
