asus aura led strip
Solved by cdominic3,
At the very bottom of this page shows what hardware has support for Aura lighting, https://www.asus.com/campaign/aura/us/Sync.html.
Deepcool 350 should be supported. It goes to the RGB header at the bottom of your motherboard, should be beneath the last PCI-E slot you have.
Nebcs ·
FancyPants101 ·
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards5
