the computer of my friend is getting old, the components are almost all outdated or failing. So he wants a new one, he mainly uses it for gaming. His budget is around 500 euros and we live in the Netherlands. His goal with this pc is to be able to play games at 1080p medium settings for at least 3 years without upgrading. What can you guys come up with?
https://linustechtips.com/topic/767186-build-for-a-friend/
I put together a solid 1080p 60FPS pc is he can save a little bit longer, this is one of the best budget builds I have built for a friend at school my self. https://pcpartpicker.com/list/LYfzRG
System
  • CPU
    Ryzen 7 5800x
  • Motherboard
    Asus ROG Strix B550
  • RAM
    Corsair Vengeance Pro RGB 3200MHz 32GB (16x2)
  • GPU
    EVGA Nvidia RTX 2080TI
  • Case
    Fractal Design Define R5
  • Storage
    WD Black SN750 500GB NVMe SSD | WD Green 2TB HD | WD Green 3TB
  • PSU
    EVGA Supernova 850W
  • Display(s)
    Asus 1920x1080p 144hz
  • Cooling
    Cooler Master Master Liquid 240
  • Keyboard
    Logitech Pro TKL
  • Mouse
    Logitech G502
  • Sound
    Logitech G733
  • Operating System
    Windows 10 Pro 64 Bit
https://linustechtips.com/topic/767186-build-for-a-friend/#findComment-9687929
