HELP! USB 3 Port Broken?!
By
TomH
in Troubleshooting
in Troubleshooting
Solved by NoRomanBatmansAllowed,
It should still work fine, just be a bit gentler with it next time. (Push it back down, if you can)
The problem you have essentially is just the force required to take the USB 3 cable out, and the quality of the soldering on the motherboard.
Doctah ·
Posted in Peripherals0 -
3
michaelb198 ·
Posted in Peripherals1 -
errorcode123_dindin1 ·
Posted in Graphics Cards2 -
Packhunter ·
Posted in Graphics Cards4 -
12
6
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies4
play_circle_filled
Latest From ShortCircuit:
