Hello. I'm having issues with my Warframe dropping frames almost every mission
My CPU load never hits above 70% and my GPU load fluctuates from 20-40%
Is there a way for me to remedy this issue?  Thanks!
Current setup I use now:
i5 2500
GTX 1060
8GB RAM
CPU: Ryzen 7 3700X @4.3Ghz All-Core with Stock Cooler
Motherboard: Asrock X570 Phantom Gaming 4
RAM: Patriot Viper 32GB DDR4 RAM @3000Mhz
GPU: MSI Ventus RTX 2080 Super 8GB
PSU: Corsair RM750X 80+ Gold Fully Modular
Storage 1: Phison 500 GB NVME SSD
Storage 2: WD Blue 1TB NVME SSD
Case: Inwin 146 ATX Case
Peripherals
Mouse: Logitech G Pro X Superlight
Keyboard: Razer Huntsman Tournament Edition
Headset: Drop x Sennheiser PC38x
Monitor 1: LG 27GL850-B 1440p @144hz Nano-IPS Monitor
Monitor 2: Asus VG248Q 1080p @144hz Gaming Monitor
Monitor 3: Asus VG259Q 1080p @144hz IPS Gaming Monitor
https://linustechtips.com/topic/761850-frame-dropping-in-warframe-need-help/
Check your in game settings, as well as your GPU utility application. It could be a few things. It could either be your cpu is thermal throttling, or the fact that its a 7 year old quad core. Most likely like another guy i just replied to, your cpu is bottlenecking your gpu from reaching its full potential.
Would it help if I try maxing everything out?
Peripherals
Make sure you disable 64 bit mode and don't use physX. I had issues with those in the past up to the point of my video drivers crashing
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
most likely no, because your cpu will only allow your gpu to work so much until for instance your CPU is at 100 percent load and your GPU is sitting at 30 Percent. This doesn't help much of anything but spike your temps. Uprade your cpu to a more modern, well rounded chip to fully utilize all of your gpu and in return have better fps and performance overall on your pc
