I'm about to replace my cpu and motherboard with newer and different cpu and motherboard and install them in my case. Is there anything I need to do before I do that or can I just swap and go. I heard I might be able to recover windows 10 or I'll have to buy a new key if worse came to worse.
https://linustechtips.com/topic/760272-changing-motherboard-help/
You will need to do a 100% fresh install of windows. Different drivers etc.. you can cause numerous issues from just installing over old chipset drivers etc for a new motherboard.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
6 minutes ago, Hollamean said:
Okay so I got to delete/uninstall all the  drivers. Anything else?
Clean install windows. That's all you've gotta do.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
