Linus did a video on this way back with some sort of Zalman tray. I believe the temps were within margin of error. Basically, no.
using a laptop cooler does not significantly lower the temp, but it helps a lot in terms of lowering the noise because the noise cpu fan of the notebook does not have to spin so fast. you will be surprised by how much noise it reduces.
http://www.amazon.com/Zalman-Minimized-Cooler-Notebook-NC2000B/dp/B0012WXFO8/ref=sr_1_1?ie=UTF8&qid=1384300039&sr=8-1&keywords=nc2000 This is what I am using. kinda old model, but it works
