11 hours ago, WiiManic said:
How did you flash the image to the USB? It sounds like the USB isn't bootable.
Did you follow these instructions? Might be worth trying it again?
I just rewrote it the way they say and it still didn't work
Edited by Tehepic
Misspelling
https://linustechtips.com/topic/743960-pfsense-help/#findComment-9466405
12 hours ago, Heller64bit said:
It looks like that make and model cant boot from third parties. You can follow up on the link: https://hardforum.com/threads/problem-booting-acer-desktop-from-cd-or-usb.1877864/
Other wise try another usb drive or perhaps a cd/DVD...
Agreed, that would be my first assumption.
I deal in shitposts and shitpost accessories.
https://linustechtips.com/topic/743960-pfsense-help/#findComment-9491297
