3 minutes ago, SenioRR said:
The CPU will get bottlenecked by the RX 460. You could also get 2x4GB sticks of RAM for the benefits of dual-channel memory.
no cpu will not get bottlenecked. benifit of dual channel is not noticeable in games and most applications. and he have pnly two slots in mobo..populationg both with 4gb sticks removes any future upgrade options
if budget allows buy a 2400mhz 8gb stick ur mobo support it
cut ur budget from ssd...buy a 120 gb ssd and use the money to buy a 1050ti. its totally worth it
https://linustechtips.com/topic/739351-build-for-a-friend/#findComment-9378138
4 minutes ago, Kantor said:
i might be wrong but maybe something like this
https://pcpartpicker.com/list/gVVB7h
no i3 is not worth the price g4560 is almost as good with half the price keep the i5
his mobo wont support 3000mhz ram..no point in paying extra for it
https://linustechtips.com/topic/739351-build-for-a-friend/#findComment-9378140
Why would you get a 1050ti ?
http://gpu.userbenchmark.com/Compare/Nvidia-GTX-1050-Ti-vs-AMD-RX-470/3649vs3640
AMD's RX series is much better for budget builds. The low-end range of GTX GPUs is laughable.
https://linustechtips.com/topic/739351-build-for-a-friend/#findComment-9378142
its better because it costs more. if he have the budget for it sure why not...
https://linustechtips.com/topic/739351-build-for-a-friend/#findComment-9378151
All the parts I have picked are getting shipped from the UK (the extra 20 euro is for shipping). I am sure that if he picks parts shipped from the Netherlands, it will cost less.
https://linustechtips.com/topic/739351-build-for-a-friend/#findComment-9378156
