Uninstalling 3DMark issue help pleasee
Go to solution Solved by 3EP,
Or get Revo Uninstaller. Free for 30 days and gets rid of previous installation traces.
SO i have 3d mark installed on my 750 series ssd but with the main files set on a regular hardrive now the problem is the hardrive is gone and the OS still tells me its installed, i go into programs and features to unintall, it open the uninstaller then say error and cannot finish. ive tried deleting the local files i found but still says its installed. I redownloaded it to try repair or reinstall it to fix the problem but i get the same error.
HELP PLEASE ITS DRIVING ME NUTS
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
https://linustechtips.com/topic/733774-uninstalling-3dmark-issue-help-pleasee/
These kinds of things I like to call "Phantom Applications". There isn't much you can do unless you are willing to backup all of your data and do a wipe of your SSD. Try going to File Explorer->Search "3DMark" in "This PC"-> Open the file-> Find a little application that says "Uninstall" and try that.
right, so there is no way to reinstall the program either?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
Thanks will give that a try
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
Thanks you this seemed to work fine, hope it didnt remove anything it shouldnt of :P
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
