Need help build a PC
Solved by Guest,
1 minute ago, gabbybabby said:No, I have a few SSDs lying around.
This one should do
@Energycore what do you think?
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor ($299.99 @ SuperBiiz)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard ($46.99 @ SuperBiiz)
Memory: Mushkin Silverline 32GB (2 x 16GB) DDR4-2133 Memory ($166.97 @ Jet)
Video Card: PNY GeForce GTX 1060 6GB 6GB Video Card ($246.39 @ SuperBiiz)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply ($45.98 @ Newegg)
Total: $806.32
Generated by PCPartPicker 2017-01-17 08:54 EST-0500
