Hi so currently i have a Netgear 200 Mbps Power line adapter in my house. I want to get more adapters in my house but cant find the model that i have online for a good price.(BTW these are are the models i currently own https://goo.gl/hLlP4D). But i did find these 500 Mbps one for a good price(https://goo.gl/gxhV1a). The question i have is will the 200 one work with the 500 one, and if i am going to run into any problems.
Thanks
https://linustechtips.com/topic/712119-power-line-adapter-help/
the 500 is backwards compatible, however it will drop to the performance specification of the 200 model, so its not really a good idea.  Replace them all with 1200 models and do it properly ;)
Please quote or tag me if you need a reply
https://linustechtips.com/topic/712119-power-line-adapter-help/#findComment-9092173
yea im planing in the future to complete upgrade the whole thingyo 1200 but i want something right now because i recently just built my new pc and i need Ethernet for it but later down ill just use the 1200 models
https://linustechtips.com/topic/712119-power-line-adapter-help/#findComment-9096187
